Review G.Skill Trident Z5 Neo RGB DDR5-6000 C30 Review: Perfect Together With Ryzen 7000
I can't believe Microcenter is giving the gskill 32 gig ddr5 ram kits at 6 ghz cl30 for free with 7700x and above purchase.
G.Skill Flare X5 Series 32GB (2 x 16GB) DDR5-6000 PC5-48000 CL30 Dual Channel Desktop Memory Kit F5-6000J3038F16GX2-FX5 - Black.
Nothing beats this deal.
Reactions: Makaveli
I have noticed 32GB has become the standard for DDR5.
Games will be able to load so much more data and make worlds so much bigger and more seamless with a 32GB standard.
This is one of the tipping points where PC will start to bypass consoles. Double the volatile memory of a console.
But, can you double them, like buying two kits or a pack of 4x16 at 6000 speed?
"Of course, gaming performance between each memory kit is pretty close, but the Trident Z5 Neo RGB ranked second overall."
The reviewer's definition of "pretty close" is laughable. In effect, it's a 5-way tie.
