[SOLVED] G-Sync Compatible monitor not allowing to enable G-Sync.
NovaTronMC
433
I recently purchased an AOC 27G2, a G-Sync Compatible monitor, however, when I open Nvidia Control Panel, on the monitor tab there is no Enable G-Sync option that i've seen with other GSync Monitors, why is this?
I have G-Sync enabled on the monitor.
Do you meet all the requirements listed here?
Reactions: NovaTronMC
Thought 900 series GPUs were compatible, lucky I just bought a RTX 2060! Thanks!
