Question G-synyc problem (?)
May 8, 2020
70
Hello, I just bought AOC 24G2U/BK, and I have the problem that when i play CS GO im just playing normally and then from nothing i got black screen for 2 seconds and then again working normally... is it g-sync issue?
It can be, I had a similar problem running my two monitors (one regular 1080p monitor and one 1440p G-Sync monitor) and G-Sync was enabled for both which caused the 1080p monitor to go black whenever I did anything.
Have you tried disabling G-Sync in the Nvidia control panel?
May 8, 2020
70
gonna try it... not disabling in panel but on the monitor, the option is not even here now
May 8, 2020
70
It didn't do without g-sync
From what I found this is a Freesync monitor that is not G-Sync certified. While you can enable G-Sync on a Freesync monitor if it is not certified there can be issues. Some monitors without certification work eith G-Sync without issues but others don’t. Have you found any reviews saying G-Sync works without issues?
May 8, 2020
70
like everyone says it's working fine...
May 8, 2020
70
it's still new i can try to refund it and buy a new one like other monitor with g-sync
