G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hey all!
Does anyone out there have advice for a G07 monitor that has a very low red
output? I have narrowed it down to either the deflection board or the neck
board as I swapped out another deflection board/neck board last night and
the red color was fine.
I have already done a cap kit and replaced the flyback and HOT on the "low
red" deflection board which did not solve the problem. And I have of course
tried the various adjustments on the neck board and the main brightness
control...if I turn the brightness up any higher, it is too bright, and the
red adjustment on the neck board is turned up as high as it will go.
Any other places to look, resistors to check, etc.?
Thanks,
Jon
Hey all!
Thanks,
Jon
