G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hi all,
I have this G07 that's fully capped and I put in a new flyback as well.
The colors are accumulated to a dot in the center of the screen. Not
sure why this is happening. I measured the voltage across the HOT and I
get 130vdc. I can't turn it up or down. Could the HOT be bad? I thought
if you're getting voltage, then th HOT is good right? Anyone ever run
into this issue? It's not the tube as I put another chassis in and the
tube works fine. Any ideas?
John
Hi all,
John
