G1 Gaming 1060 coil whine + high temps when idle
chrysoulis
Commendable
Sep 28, 2016
8
I bought 2 weeks ago a g1 1060! Suddenly yesterday i heard a strange noise (coil whine) from gpu.I opened Hw Monitor and i recognized that my gpu when it was in idle started to rise temps without touching the pc.Fan stop led turned off and temps were keep rising until i turned the pc off.Also i switched the gpu to the second pcie slot and i had the same problem.The problem started 15-20 minutes after start up every time
I have heard of this issue i don't think its anything to worry about as its fairly common it seems to happen more with the cheaper reference cards sorry i cannot help am sure someone else has a more detailed answer
Joe
Thanks for response!
I sent it to RMA but i want to know if its an issue for 1060s or with which issue is related
Thank you again and i hope someone has an answer!
