G1 vs G2 EVGA PSU and recommended PSU wattage for my build
Sir_Herbert
19
When looking at PSUs, specifically EVGA, there were G1 and G2 versions of the same wattage PSU. I looked this up and saw that there were 2 different generations. I also saw that the PSUs have different makers in the different generations. So, my question is, what makes one generation better than the other, and will generation 1 work just as fine and last as long as a generation 2 PSU?
Also, pc part picker says that my system will only pull a max wattage of 342w. This is significantly lower than what NewEgg's PSU calculator says my system will pull (652w). I was originally planning to go with the G1 650w PSU from EVGA but now I don't know if I should get something a little bit more powerful and if I should also get a G2 PSU. Thanks.
Here is my build: http://pcpartpicker.com/p/qDrxzy ; I will be putting Windows 10 on it and I do not plan to overclock right away, but I would like to have the power to be able to do so. Thanks again
Thanks for the reply! As for the wattage of the power supply, what do you recommend for my build?
550w would be plenty of power for the system. if you think you will want a second 970 in the future then at least 750w would be needed. other wise go with whatever is cheaper between the 550 and 650w one. i know sometimes the higher wattage is cheaper due to sales or rebates at times :)
