Hi everyone, I have a relatively new ASUS G16 and have had this issue since the start, I’m not too concerned about it but just wanted to definitely check it’s coil whine?
The issue mainly occurs when the G16 is on battery mode, as soon as I plug in the AC adapter the issue tends to go away / reduce.
It sounds quite loud on the audio recording, but you can’t heard it unless you’re in a silent room.
Is this coil whine which doesn’t affect the functionality of the device? It isn’t there all the time and is dependent on what is loading.
Many thanks
vocaroo.com
Many thanks
Vocaroo | Online voice recorder
Vocaroo is a quick and easy way to share voice messages over the interwebs.
