G3258 and 750ti PSU advice
1982danjones
49
Does anybody know if an evga 500w 80 plus PSU would be OK with an Intel g3258 and 750ti. Along with a siedon 120v cooler. And 2 ssd drives. I plan to overclock the CPU to around 4.2.
Any idea on the total power draw.
The GTX750ti is very power efficient. Likely even a 300w psu would do the job for you.
I like your combination. It is a good balance between cpu and gpu.
Why 2 ssd drives? A single larger drive will be cheaper, perform better and have longer endurance.
4.2 is a reasonable OC expectation.
It does not require any exotic cooling.
I prefer the simplicity and reliability of a simple tower type cooler with a 120 or 140mm fan.
FWIW:
My canned rant on liquid cooling:
------------------------start of rant-------------------
You buy a liquid cooler to be able to extract an extra multiplier or two out of your OC.
How much do you really need?
I do not much like all in one liquid coolers when a good air cooler like a Noctua NH-D15 or phanteks...
FWIW:
I do not much like all in one liquid coolers when a good air cooler like a Noctua NH-D15 or phanteks can do the job just as well.
A liquid cooler will be expensive, noisy, less reliable, and will not cool any better
in a well ventilated case.
Liquid cooling is really air cooling, it just puts the heat exchange in a different place.
The orientation of the radiator will cause a problem.
If you orient it to take in cool air from the outside, you will cool the cpu better, but the hot air then circulates inside the case heating up the graphics card and motherboard.
If you orient it to exhaust(which I think is better) , then your cpu cooling will be less effective because it uses pre heated case air.
And... I have read too many tales of woe when a liquid cooler leaks.
google "H100 leak"
-----------------------end of rant--------------------------
Your pc will be quieter, more reliable, and will be cooled equally well with a decent air cooler.
