G430 *buzzing* problem
Hi community,
this may not be the right place to put this on but i have a problem. When i make a bass-heavy song quieter/louder i can hear buzzing in my year. I tried with the doggle and without it. I am not annoyed by it, i'm just asking if this is a problem. And yet another question. Is the G430 7.1 even without the doggle, cuz im using realtek sound manager and it doesn't recognize the headphones with the doggle but with 3.5. The point is that when im using the doggle the logitech software's 7.1 playback works perfectly but the realtek sound manager doesn't. I really don't know if i should send them back or if i should just keep it with it. I have had them for christmas and sometimes when i am on teamspeak and i enter steam after i'm on teamspeak (with doggle) the headset freaks out and it starts turning itself on an off. Thanks to everyone who answers. I'm not really into headphones as much as i am in PCs.
I have a pair of g430s and I find that when I have the volume on my computer turned up very loudly there is a lot of static noise. Also if you have the mic turned on via the little switch on the cord it makes a noticeable static sound as well. Try turning all music off and then just turn it on and off and see if there's a difference. Don't know if that is exactly your problem but those are just a few things i noticed with mine. Also, yes it does need to be connected to the dongle in order to be a 7.1 device.
You should be able to get the latest drivers through the Logitech gaming software
You replied to one of the most important questions i have asked for. Ok, thank you so much, i just noticed that when i'm using the headset without the dongle the mic is just horrible. I'm not sure if that's is a problem, but i'm not really worried about it. To the other stuff, i can live with the static noise. Thank you.
I have but i still think there might be some issues.
Now i have static sound after downloading the newest logitech software and restarting my computer. I have disabled the mic like i always had to but there is strange sound when on 100% volume.
I do still get the static sound when at 100% volume even when the mic is off. However I'm not sure what could be causing it if it is not the normal static sound. If you cannot find anything I'd suggest sending a ticket to logitech support. They usually aren't too bad with sending replies on a timely basis
I have had my headset on 100% volume all the time. I just fixed it, dont ask me how.
To whoever is reading this with the same problem at some point of their life:
Check if everything is connected properly,
disable the mic from the recording devices
try updating your headset's firmware
send a ticket to logitech and probably get a new dongle
Sorry for your time wasted UnforgivenGamer and thank you!
