D Dropment Distinguished Oct 23, 2016 855 10 19,015 May 6, 2017 #1 my budget is $600 and im going to be doing some gaming and watch videos in 1080p and have many tabs open
Solution Robert Cook May 6, 2017 some gaming? I think the G4560 might work out fine. we do not know what ryzen 3 will bring so I would say get that wonderfully cheap pentium.
Robert Cook Expert Ambassador Dec 15, 2014 6,113 0 21,960 May 6, 2017 Solution #2 some gaming? I think the G4560 might work out fine. we do not know what ryzen 3 will bring so I would say get that wonderfully cheap pentium. Upvote 0 Downvote Solution
atljsf Honorable BANNED Jun 17, 2015 4,910 46 12,990 May 6, 2017 #3 with that budget, i would go for the cheaper g4560, the cheapest r5 is twice as expensive any gpu you would like to get? the 600 budget includes monitor or we are talking about the pc only? i would get this https://pcpartpicker.com/list/q6qrCy you can change psu and gpu, remove the ssd also but i wouldn't remove the ssd if you go for a r5, taking that list and replacing ram, mainboard and usign faster ram https://pcpartpicker.com/list/gNxxm8 the budget doesn't work anymore another place you could save is the gpu, the 1060 is great but is also expensive, so a 1050ti could be a good option depending on your needs Upvote 0 Downvote
D Dropment Distinguished Oct 23, 2016 855 10 19,015 May 6, 2017 #4 i was looking at the g4560 for a while and this was an ideas from when the cpu came out https://pcpartpicker.com/list/wXx9LD Upvote 0 Downvote
Robert Cook Expert Ambassador Dec 15, 2014 6,113 0 21,960 May 7, 2017 #5 Dropment : i was looking at the g4560 for a while and this was an ideas from when the cpu came out https://pcpartpicker.com/list/wXx9LD get the $20 logitech keyboard mouse combo, and that is nicely below $600. RGB is overrated. I would try to get 2X4GB of RAM though. Upvote 0 Downvote
D Dropment Distinguished Oct 23, 2016 855 10 19,015 May 7, 2017 #6 There is 2 ram slots in the mobo so i was planning on upgrading that to 16 gb of ram Upvote 0 Downvote
Robert Cook Expert Ambassador Dec 15, 2014 6,113 0 21,960 May 7, 2017 #7 Dropment : There is 2 ram slots in the mobo so i was planning on upgrading that to 16 gb of ram fair enough, but do realize you will be at single channel speeds until you upgrade. Upvote 0 Downvote
madmatt30 Titan Ambassador Jan 1, 2013 24,571 647 91,240 May 7, 2017 #9 You should still consider ryzen mate at your pricepoint IMO. Even if it means compromising the ssd (120gb isn't enough anyway IMO) & dropping to a 1050ti PCPartPicker part list / Price breakdown by merchant CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor ($188.88 @ OutletPC) Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($84.99 @ SuperBiiz) Memory: Crucial - Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory ($59.99 @ Newegg) Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.45 @ OutletPC) Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card ($118.68 @ Amazon) Case: Zalman - R1 ATX Mid Tower Case ($47.27 @ Amazon) Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg) Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse ($29.99 @ Newegg) Total: $617.24 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2017-05-07 14:28 EDT-0400 Upvote 0 Downvote
