So, to describe the problem. My headset started 2-3 weeks ago to burst static noise for half a second, this caused the mic on the G635
to disable (or something), but simply disconnecting and reconnecting to whatever voicechannel i was in discord fixed it. This started happening more and more frequently, and by now discord is basically unusable.
It's also sometimes stopped making sound for a few seconds.
Worst of all, sometimes the noise increases suddenly by A LOT. The noise gets mixed in with a good amount of static, and i have to pull the headset off as fast as possible if i don't want tinnitus.
I've tried updating the drivers and plugging it into different usb ports on my computer. Nothings changed. Do any of you know anything else i could try?
Thanks.
Thanks.
