i have to replace the dead battery on my asus G751JM. on amazon there are many non OEM batteries but all varying in dimension. Can someone please recommend me which one to get and whether the dimension being different matter... Thanks
If the dimensions are minor differences, you should be ok. Sometimes you will get a battery that is a bit thicker, but still mounts the same, for instance. Stick with reputable sellers. Look at their feedback rating.
