G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi,
I am running the above borard with an Athlon XP 2600+, the CPU is not
overclocked. I was running an artic cooling CPU fan that was letting the
CPU get too hot. MBM5 and the BIOS Health display show a CPU temp of up
to 65° in Win98, even when not doing anything. The Case temp will show
up to 48° too. I have added a case fan which blows cool air directly
towards the CPU cooler, and even cut some holes in the roof of the case
to let any hot air vent.
Even when the CPU was getting up to those temps, the CPU fan did not
appear to run any faster, all speed measurments on the fan were always
about the same RPM number.
Today I added an Aerocool HT101 JR heatsink and cooler, this keeps the
CPU around 5° cooler than before, but it still seems very hot to me.
CPU voltage is around 1.7v, so I am a bit stuck about what I should do next.
Seems like my BIOS does not offer any features that allow the fan to be
controlled.
I have added round IDE cables to that the airflow is good within the case.
Is the temp. too high, what else can I try? Ideas anyone?
Cheers Brian
Hi,
controlled.
Cheers Brian
