GA-8IPE 1000Pro-G Audio Question
tp
39
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Just got a GA-8IPE 1000Pro-G and it is working beautifully with my P4
3.0 and Win XP (with 1GB dual channel memory, 80 GB SATA drive and a
NEC CDR/RW drive)...I want to add a second optical drive (a DVD drive)
but can't figure out how to connect the aduio cable to the Mobo (I'm
using the onboard Realtec chip)...I find only one "CD-IN" connector
(no "AUX-IN" or anything like that)...Is there a way to connect a
second optical drive to the onboard sound chip or do I have to get a
separate soundcard? My preference would be to continue to use the
onboard setup...
Any help would be greatly appreciated...
Thanks,
TP
"TP" <apiro@comcast.net> wrote in message
news:aa9d7e06.0404150422.6248ca97@posting.google.com...
> onboard setup...
Win98 onwards do not require the audio cable, use Digital Audio Extraction.
Enable it in device manager or control panel depending on your OS.
