Solution das_stig Aug 16, 2017 Should be OK, but make sure you running that latest BIOS first and perhaps put some cheap 3rd party VRM heatsinks on the motherboard.
T TJ Hooker Titan Ambassador Apr 15, 2014 11,629 1,766 72,390 Aug 16, 2017 #2 Gigabyte's website lists support for up to [strike]135W[/strike] 130W CPUs with that mobo. It doesn't look like it has any VRM heatsinks however, so I'm not sure how it would actually work with a [strike]135W[/strike] 130W CPU. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Aug 16, 2017 #3 130 Watts. The CPU Support also differs according to PCB revision number. rev. 1.0 rev. 2.0 rev. 3.3 Actually, 135 watt CPUs are listed as N/A. Upvote 1 Downvote
L laassiim Commendable Feb 17, 2017 54 0 1,640 Aug 16, 2017 #4 Right now I have q6600. I want upgrade q6600 to X5460. X5460 is 120w Upvote 0 Downvote
das_stig Glorious Jul 24, 2009 8,626 218 46,390 Aug 16, 2017 Solution #5 Should be OK, but make sure you running that latest BIOS first and perhaps put some cheap 3rd party VRM heatsinks on the motherboard. Upvote 0 Downvote Solution
