Question GA 970a DS3 power issue
DilawU
143
Hello, I have an GA 970a DS3 mobo with an FX 6300 and GTX 750 TI, the issue with it is that it powers on and then right off, I placed it on a cardboard with only the PSU and it does the same thing, tried different PSUs, does the same thing, it worked perfectly fine until the power went off in the house. This is the second time it does the exact same thing after the power goes off, and then it starts working after a few days.
Lutfij
Make and model of the PSU you're using to breadboard the system? How old is the unit? Judging from what you've stated above, it's a PSU issue. Either it's old and can't deliver the necessary amount of power for the entire system or the PSU is new and is not up to snuf.
DilawU
143
With a CX450M which is working cause I'm using it.
Also, the whole system was running just fine, the only thing that stopped it from running was the power outage. It happend twice in like a month, it did the same thing twice, and now if I wait a few days and try again, it will power on, it makes no sense to me.
DilawU
143
Well that's all I have on the cardboard
Mobo : 970A DS3
CPU : FX-6300
GPU : GTX 750TI
RAM : Samsung 2x4GB 1333MHZ CL9
PSU : CX450M
