F Farouk Beshai Reputable Apr 1, 2015 2 0 4,510 Apr 1, 2015 #1 Ethernet port not even detected by PC as if it's not there at all
Solution Phillip Corcoran Apr 1, 2015 Is the wired network adapter listed under "Network Adapters" in Device Manager" or is it listed as "unknown device" (? symbol)? If listed as unknown device, try reinstalling it's driver (Realtek LAN Driver): http://www.gigabyte.com/products/product-page.aspx?pid=4672#dl
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Apr 1, 2015 Solution #2 Is the wired network adapter listed under "Network Adapters" in Device Manager" or is it listed as "unknown device" (? symbol)? If listed as unknown device, try reinstalling it's driver (Realtek LAN Driver): http://www.gigabyte.com/products/product-page.aspx?pid=4672#dl Upvote 0 Downvote Solution
Hawkeye22 Glorious Feb 10, 2006 11,442 3 49,065 Apr 1, 2015 #3 Is it enabled in the bios? If so, do you have the driver installed for it? It's possible that the onboard ethernet controller went dead. In this case you can replace it with a standard NIC (network interface card). Upvote 0 Downvote
