Hello there,
I recently built a new PC and am having some issues.
Specs:
Motherboard: B75M-D3H
CPU: i7 2600k
RAM: 16GB - unsure of details, but am pretty sure DDR3
Power: Corsair CX750M
HDD: 2x 1TB, no RAID setup
SSD: Samsung 500gb
Heatsync: Corsair H60
GPU: MSI R9 390
I think I got all the specs there. Let me know if I've missed anything.
Onto the issue:
The build went fine, booted to BIOS no problem. Installed Windows 7 pro 64-bit, no issues. Installed latest BIOS version (F15) and all necessary drivers.
The issue starts when we're ready to boot to the GPU display. No signal is returned. Not sure what the issue is there, but had done some research previously about newer GPUs not booting and decided to set to Legacy boot mode rather than UEFI (bad move apparently). After making this change, the computer will turn on, but not boot up. I get no display signal and mouse/keyboard also are not responding (I have a backlit keyboard, the LEDs do not turn on as usual, same with laser on underside of the mouse).
Troubleshooting:
Here is what I've tried based on message board posts and the motherboard's user manual. All attempts were done with power and all other devices removed (no USB, display or any other ports used).
1. Tried to clear CMOS by touching a screwdriver to the two pins as per he user manual. No success.
2. Removed the motherboard's battery. No success.
3. Used a spare jumper to try to clear CMOS. No success.
4. Remove motherboard battery and let it sit out over-night. No success.
5. Re-seated everything except CPU which has a liquid cooling block so it is not convenient. Also do not want to handle the CPU if possible. This means I re-seated the RAM, GPU, wireless card, SATA connections.
I'm not convinced the motherboard got fried during any of this, and besides, the issue started from rebooting after changing BIOS settings. I've made sure to ground the case as well as myself before touching anything. Any help would be greatly appreciated as I'm out of ideas and really want to get this rig working.
Thanks in advance,
-Tim
Specs:
CPU: i7 2600k
SSD: Samsung 500gb
GPU: MSI R9 390
Onto the issue:
Troubleshooting:
Thanks in advance,
-Tim
