GA-EP43-DS3L -- HELP! System won't post; Bios / mobo issue
GlumBum2
14
Not sure why this is happening, but tonight my computer crashed, flashed a blue screen super fast (too fast to read), and turned off. It then tried turning back on, but after a few seconds, lost power, and turned off again. Whenever I give the machine power, it repeats this process over and over. I'm kind of afraid to give the machine power; after a few times of letting the machine sit for a bit and coming back to it, the same problem occurs, and the system doesn't even have time to post. I'm afraid that this might damage the other components on the motherboard.
The last few days leading up to this event have had about three or four blue screen's reporting stop code errors. I'm not sure where they came from, specifically, but in between restarts, during the mobo report screens, the system reported BIOS errors and said that it was scanning the bios on the hard drive, and reloading it (or something similar). I had not had time to update the bios before tonight, and i hadn't had time to run a memory diagnostic, but i did run chkdsk with the /F parameter. It did find and recover a few errors, but nothing supremely critical (as far as i can tell).
The stop code errors that i got with the Blue Screens, on different occasions, were as follows --
0x0000000A (IRQL_NOT_LESS_OR_EQUAL error, ... device driver issue?)
0x00000024 (ntfs.sys error... or a device driver, again?)
here are the specifics for the 0x024 error--
0x00000024 (0x001902FE, 0xBACDF40C, 0xBACDF108, 0x8051AFD6)
I can't even post, so I can't tell if it's an OS system problem, or what.... Is it possible that the board itself isn't holding the charge when i give the machine power? (my first guess)? Could my CMOS battery be dead? I don't even know what the very last blue screen was.... I've tried starting my machine with all the hdd's disconnected, so i get the feeling that it doesn't have anything to do with the NTFS stop error.
Anyway, here's my hardware config....
Gigabyte GA-EP43-DS3L motherboard, rev 1.0, bios rev F4,
XFX GeForce 9800 GTX in the PCIE x16 slot
2048 MB of Crucial Ballistix, DDR2-800; two 1GB sticks in dual channel
Intel Core 2 Duo E8400 3.0 GHz (Wolfdale core), with the stock intel cooler on top
Corsair CMPSU-650TX (650W psu with 52A on the 12V rail... more than enough.... right?)
I'm using XP SP3, technically, I had SP2 a few days ago, and installed SP3 some time after the problems had started but before any critical failures...
also using an 80gb SATA2 hdd for my os, a 500gb SATA2 hdd for data, another 250gb SATA2 hdd for my data, and an old 300gb ATA hdd for old stuff that i migrated over...
can't think of anything else to list here...
please help me out, i'm kind of freaking out. never had a failure this catastrophic before. thanks very much.
Sounds like a RAM issue to me. If you reset the CMOS you should then be able to post. You should then go into the bios and set the RAM timings and voltage to the manufacturers specs. The next thing you should do is run Memtest86+ for at least 8 hours. If it reports any errors with the timings and voltage manually set correctly, it's probably time to RMA the RAM. The latest round of Crucial RAM seems to have some problems.
GlumBum2 have tried to use just 1 stick of ram.also the battery is easy to check if you can't lay your hand on a volt meter.if you are not getting any post beep,the first thing I would try is the 1 stick of ram,also doing a fresh install of the os I would try next,the power supply is a good one so I don't think it's the problem.also if you do a fresh install,try booting up with just the 1 os hd,and see if it will post.hope this help you out .if not post back and there will be plenty of help at toms that for sure.
i've tried booting with one stick (i tried with either one) and I've tried every variation of booting with a single drive in. I don't even get to the POST beeps before the system loses power. it starts, runs for two-three seconds, does NOT beep, and shuts off. about 5 seconds later, it repeats the process indefinitely.
how do i reset the CMOS?
Look in your manual. There will be two pins on the motherboard that will need shorted out with a jumper for a few seconds. Clearing the CMOS should allow you to boot.
Sometimes if I push an overclock to far on my Gigabyte board it will go into the boot loop also. Sometimes I can fix it by just turning off the PSU switch on the back of the PSU for a few seconds.
I would also upgrade the BIOS as soon as you successfully get the board to boot. The latest BIOS is F8 and there are a lot of memory compatibility fixes aparently:
F8 2008/09/22
1. Fixed Vista S3 resume sometimes failed
F7 2008/08/18
1. Support DDR2 speed to 1200MHz and beyond by overclocking
F6 2008/07/23
1. Enhanced memory compatibility
F5 2008/07/08
2. Update CPU ID (Support Intel Wolfdale/Yorkfield E0-stepping CPU)
F4 2008/06/19
1. Fix VGA compatibility issues
F3 2008/06/12
1. Enhance system performance and overclock capability
GlumBum2 also try checking to make sure the cpu heatsink is secure,that is a push pin heatsink I believe,and maybe one or more push pin came loose.you can just pull the battery out for couple of minutes to check the cmos,you will have to reset time and date after that if it boots.it still sound like ram problem to me.if you have excess to another pc you could try them in another pc .post back help in on the way.
awesome i'll try throwing a jumper on the cmos pins and get back to you.
I already reseated the heatsink for the cpu.
i'll see if i can find an extra stick of DDR2 to try with
so far using the jumper to clear the cmos does not work. I've had to use my own jumper because i can't find one that is connected directly to the mobo (like to the 1 and 2 pins), and I tried resetting it by leaving the power off for a few minutes, giving the board (but not the whole system) power with the jumper on the clr_cmos pins for a few minutes as well. None of this causes any change in the repeating boot process..... i'm going to try ejecting the cmos battery for a few minutes next...
yeah, i've tried both sticks separately, though
when i try to boot again i'll try with one stick... a few minutes....
so resetting the cmos did nothing. I tried using the jumper method, leaving the jumper on the clr_cmos pins for a minute or so.
I also tried pulling out the battery for about five minutes and leaving the machine completely alone.... after I put the battery back in, I powered on the machine using a single stick of ram, and the same problems occured. No beep, no post, just power and then it died. I tried boh sticks of ram separately. Could I have burnt something out on the board itself? i think that's the last logical conclusion i can come up with.....
GlumBum2 you can check the caps on the board to see if any are puffed up on the top.I still believe the ram is bad ,if you can get a hold of another set of 800 just to try that.
yeah the capacitors are all fine... this board is supposed to be built blow-proof and bios corruption proof... it's got that gigabyte dualBios **** thats supposed to retool the bios if it ever becomes unstable...... and yet, the whole system wont even POST (lame)
...so i should just try buying new ram? i mean, it's two sticks... what are the odds of BOTH sticks going bad simultaneously? if that actually occured, wouldn't it be a little dangerous to feed more ram into the board (perhaps the board itself f'd up the sticks of ram)
GlumBum2 answer to question is slim but I have seen it happen.answer me this when you stick 1 stick of ram in the mobo which bank are you putting it in?
The leftmost bank, slot 1.
Dual channel on this board works with Slots 1 & 3 mated, and slots 2 & 4 mated. So when I have one stick in, it's in slot 1. When I have two sticks in, they populate slots 1 & 3.
(slot 1 is the slot closest to the cpu socket, slot 4 is farther away)
i did that, too. I tried booting with an individual stick in each of the four slots. I did this with both of my sticks of ram.
when i removed the battery, i DID unplug the psu (i thought you were supposed to unplug it... right?) I only plugged the power back into the psu after i had replaced the cmos battery.
Honestly i couldn't find a great tutorial anywhere for resetting the cmos on a modern board. For example, i couldn't find a jumper with pins labeled "1 and 2" on the actual board; my mobo just has a pair of pins labeled "CLR_CMOS." when i tried to reset using them, i powered down the system, jumpered the CLR_CMOS pins, waited a minute, then removed the jumper and powered it back on. This had no effect.
When I pulled out the battery, I had the PSU unplugged from the power cable and I pulled out the video card to get the battery out. I then replaced the video card and waited five minutes, then put the cmos battery back into the board and plugged everything back in and powered up.
This also produced no results :-/
Also, I get the feeling that it's not the PSU, because up until the problem went critical, I was pumping my video card and my cpu maxing things out playing video games, and even playing video games while working my cpu by watching videos (basically dual loading the cpu by asking it to call codecs and calculate geometry at the same time... thats what dual core is for 😛)
Hey I'm still having these issues with no resolution. I've tried everything, including resetting my CMOS (I don't have a great method for doing it... I just remove the cmos battery for a period of time, then plug it back in?)..
i've ordered new ram and its on its way....
