GA-G41M-Combo DDR3 Problem
  • Thread starter Thread starter Deleted member 1390739
  • Start date Start date
D
Guest
I have a GA-G41M-Combo rev 1.3 and i want to replace my DDR2 rams with a 4GB DDR3 ram (1333).
Ram: KVR1333D3N9/4G - SP.
It should be possible by overclocking but it won't work.
After checking the memory support list. I only found the 2GB version of the same ram.
Does that mean I cannot use the ram on this board ?
CPU: Core™2 Duo Processor E8400.
GPU: None.
"F3", I updated the bios after I bought the motherboard.
1. GA 41M combo need Dual sided chip RAM if not then imposible to run on this Motherboard
2. Only works branded RAM not cheap . Kingston works well
3. It should not be more then 1333 MHz
The Ram mentioned above is a Kingston, and it's exactly 1333MHz.
Same here ppl, it should work, reseted cmos and everything, it just wont work!!!
