GA-K9N-SLI Motherboard (not the Pro or Ultra)
AMD 3200 64 bit processor
250 Gig PATA HD
Two 1 Gig RAM
Geforce 7600GT (FORSA)
WinFast DTV 1000T Tuner card
450W PS
I have had a new system for about 8 months now. No problems until about 2 weeks ago when my computer froze, the graphics on the screen turned to lines, the video card fan increased in speed while the CPU fan stopped and a weird fizzing noise came from the motherboard. I also couldn't turn the computer off via the switch on the case or reset. Having completed a windows update prior to this I thought (for no real reason) that this was the problem (driver issues maybe).
I downloaded speedfan to montor all temperatures and did a system restore to 2 days prior to the problem. All temperatures fine for two weeks and no problems until it happened again (coincidently after another windows update, the same one which you can do with the option of turning off the computer and installing the updates while it shuts down).
It hasn't gone this time, having changed all other hardware on system with no hard drive connected (borrowed my brothers stuff). Only have the RAM, CPU and videocard in system (all which have been changed with brothers similar hardware) and the problem still happens. also changed power supply.
It will happen even in bios. It occurs after approx. 2 minutes and then after 15 seconds when the computer is turned straight back on. If the computer is let to sit (5 minutes) it will occur after two minutes again (i can get into windows fine if it is within the time frame).
I have already tried the latest bios update, still not fixed. Will be taking the MOBO back to the shop as still under warranty, thought id make sure there is nothing i can do to fix it before i do.
I inspected the motherboard but nothing looks wrong (ie burnt or anything coming apart).
Need any other details, let me know.
Thanks all.
250 Gig PATA HD
Two 1 Gig RAM
450W PS
Thanks all.
