GA-M61P-S3 Onboard LAN problem
nukie83
20
EDITED:
Now i can access the net. It turns out I can't use internet with more than 2 connections with the hub.
My hub is linksys brand. Is this problem anything to do with the GA-M61P-S3?
check the bios again see if the onboard lan is enabled
check device manager.
try removing device then install the drivers from the MB disk, or let windows find it
in the bios there is one called MAC LAN and probaly one more called something else.
btw i tried removing the software and disabling those. No go. THe windows don't even attempt to find it...
it shows up at Nvidia Network controller on the device manager. If i delete everything.. probably nothing at all.
Okay now the problem is slightly different. I cant connect to the internet with more than 2 computers. 3 computers are hooked up to a switch atm.
no. a hub atm. works fine with 2 but doesn't work with 3 for some reason.
