Hi.. new here,
I know this shouldn't be happening but I am getting a weird result in both BIOS and from the easytune5 motherboard monitoring utility.
The CPU temp is at 20C at idle but the system temp is much higher.
I made two screenshots the first when the cpu is at idle and the other when I alt tab out of a game (bioshock) so I'm putting some load on the cpu.
In the first shot the cpu is at 20C and the system temp is at 37C in the second the CPU temp goes up to 28C and the system temp remains at 37C. Initially I thought they were mislabelled somehow and the wrong way round but since it's only the CPU temp that goes up it leaves me confused.
In the shot there is also a speedfan result and the label of core relates to the gpu as it's the same as the result in rivatuner for the gpu temp and rises and falls to the same value.
I'm running
Q6600 at stock
ga-p35-s3
8800gts 320mb at stock
2gb 6400 corsair ram
530w hiper psu
akasa 965 side blowing hsf tower
Anyone any idea?
Thanks guys.
I'm running
Q6600 at stock
ga-p35-s3
530w hiper psu
Anyone any idea?
Thanks guys.
