ga-z170-hd3p MOBO will not power on. Bad MOBO or some other problem?
SabaBoBaba
Commendable
Dec 11, 2016
Building a new PC, see part list below. Assembled the PC hit the power button and nothing. No beep, fans or lights. Checked all my connections and reseated everything, no change. Took everything out except 1 stick of ram in the 1 slot, the CPU, cpu fan, and system speaker, no change. Changed out the PSU to a brand new one and still nothing. Kinda out of ideas. Any help would be appreciated.
EDIT: While I was posting this I left the bare bones set up on the table plugged in. I went to tear it down to check to see if there were any bent CPU pins and found that this component https://drive.google.com/file/d/0B8maID9_gG7cUnlDSG9lTjZuU1E/view?usp=sharing (The one centered with gigabyte on it) is piping hot, burnt my fingers on it. The manual states that it is the Intel Z170 chip set. What does this mean? I assume it means that MOBO is toast but Im mostly concerned if the CPU has been damaged.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (Purchased For $217.99)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (Purchased For $27.95)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste (Purchased For $7.39)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard ($109.89 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory ($101.59 @ Amazon)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive ($64.88 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (Purchased For $45.71)
Video Card: Asus GeForce GTX 1060 6GB 6GB Turbo Video Card (Purchased For $263.99)
Operating System: Microsoft Windows 10 Home OEM 64-bit (Purchased For $84.88)
Other: Kopul 3' Dual Link DVI-D Cable (Purchased For $7.95)
Total: $932.22
Generated by PCPartPicker 2016-12-11 14:06 EST-0500
I did what was suggested and no dice. I suppose I'll have to try to RMA the board. Is Gigabyte usually good about standing behind their product?
TBH, no idea. They are a very reputable and experienced company so I would assume so.
Ok thanks for your help. I just submitted a RMA request to Gigabyte so here's hoping that they'll honor it and that the only problem is the motherboard and not the $218 CPU or $264 GPU. Pray to the computer gods to have mercy on this humble newbie.
Good luck :)
