Hi everyone
I have a system based on a Gigabyte ga-z68x-ud3h-b3 (http://www.gigabyte.com/products/product-page.aspx?pid=3974#ov) motherboard and a Core i7 2600K CPU. The problem is that I cannot make the system boot unless my dedicated graphics card is inserted into the pci-e x16 socket. The motherboard is based on the Z68 chipset which allows for the use of both dedicated gfx and the Sandy Bridge build in GPU.
I just wanted to measure the power consumption without my Nvidia GTX470. So I opened up my case, unplugged my GFX and booted up my system. Everything went well in the beginning. It successfully loaded my OS and I began locating my prime95 but then it suddenly rebooted. This load the OS and spontaneous reboot rutine went on 3-5 times. After that I want able to boot at all. Power would come on (fans jerking, mobo LEDs lighting) and then turn off again. This power on, off, on, off cycle would just continue forever. Then I could plug the GTX470 back in, boot and load the OS again successfully. Then I could unplug it again and it would be back in the power on/off cycle. I have tried everything, all combinations of bios settings, resetting cmos and so on.
What the *u** is going on? The system worked without the gfx for serveral boots / OS loads. Then all of the sudden it does not.
Any suggestions as to what I can try to do and/or why this is happening?
Best regards
Wuhtzu
Best regards
Wuhtzu
