GA-Z87X-D3H Gigabyte Motherboard/System goes to deep sleep and will not wake up?
ticktoc
31
I have the following System:
I5-4570 CPU
Gigabyte GA-Z87X-D3H motherboard
8 GB Kingston HyperX Ram
Crucial MX-100 SSD 120 GB drive for Windows 7 SP-1
WD Black 1TB HDD
Corsair 430M PSU
I have my Bios set so that movement of the Mouse is suppose to wake-up the system when it goes into 30 min Idle time. I've noticed lately that it will not wake up. I have to press the power button to boot up. Ever so often it will give a fatal error message. Reboot in normal mode. Could anyone help me with this. Any suggestions as to what may be causing this? Thank you
well there seems to be some problems with SSD and sleep mode. although only some of SSD does. suggest disable sleep mode/hibernate.
link on SSD and sleep mode issue: http://arstechnica.com/gadgets/2011/06/ask-ars-do-solid-state-drives-cause-problems-with-sleep-mode/
Thank you qazzi, I had suspected the ssd, so I am going to make sure drivers for it are up to date. I am going to take your suggestion and disable the hibernate mode. Thanks for your response it was very informative.
