R Recchi Commendable Dec 9, 2016 3 0 1,510 Dec 9, 2016 #1 When I run a game the pc restarts qhen I have this gpu on. When I try my other gpu (HD 6570) it runs ok. my configs are: ga78lmt usb3 fx 8350 4gb ram xigmatek 600W gtx 750 ti ps: Sorry if I'm at the wrong place.
elbert Champion Jan 11, 2005 9,704 6 51,165 Dec 9, 2016 #2 Have you tried uninstalling your GPU and use DDU to remove all leftovers AMD configs? Then try installing the nvidia drivers. http://www.guru3d.com/files-details/display-driver-uninstaller-download.html Upvote 0 Downvote
R Recchi Commendable Dec 9, 2016 3 0 1,510 Dec 9, 2016 #3 elbert : Have you tried uninstalling your GPU and use DDU to remove all leftovers AMD configs? Then try installing the nvidia drivers. http://www.guru3d.com/files-details/display-driver-uninstaller-download.html Yes, I did! Upvote 0 Downvote
elbert Champion Jan 11, 2005 9,704 6 51,165 Dec 9, 2016 #4 Have you got the latest mottherboard bios F4? http://www.gigabyte.com/products/product-page.aspx?pid=4305#bios Upvote 0 Downvote
R Recchi Commendable Dec 9, 2016 3 0 1,510 Dec 9, 2016 #5 elbert : Have you got the latest mottherboard bios F4? http://www.gigabyte.com/products/product-page.aspx?pid=4305#bios Can't confirm this right now, but I believe I do Upvote 0 Downvote
