GA990xa-ud3, fx8350 overclocking issues
raipe
28
Hello,
Wanted to overclock the cpu but i cannot change vcore manually? I can only set auto, normal or +0.0025 or -..? Also the stock vcore seems to be 1.428? I have the newest bios and i should be able to set it manually but i just cant.
Thanks but nah mate. There just is no option to manually change if, +- are offset values
Haven't, Could try tho. I just think its bios-related cause it also doesnt show the current voltage there which is weird. Im able to OC it quite nicely with offsets tho.
