Hello,
I have a Gainward GTS 250 (1Gb) video card and its fan stopped working. The card now heats up to over 90 degrees even while simply browsing and then shuts down.
http://www.gainward.com/main/vgapro.php?id=118 (same model but with more memory, but basically the same)
I've "installed" a 120mm case cooler under it for now, but I'd like a more permanent solution.
I'd like to know what cooling options I have for this type of card on a low budget (otherwise I guess it's better to just buy a new card considering how old this one is, but I don't really need something better atm 😛) I've tried finding one myself but most sites don't show this specific card in the compatibility lists so I'm afraid to buy anything.
Thanks in advance.
Thanks in advance.
