Game installation problem
Open your dvd drive and close it again. goto my computer and and right click dvd drive and select open so you can view the files. on the setup.exe file right click and select properties. then click compatibility tab. and run in compatibility for xp sp3 or vista or vista sp1. this should work. if your getting a library not registered error then this will fix it. also this should help with the insert dvd problem with vista & 7.
If you have number that is similar to this tell me...
something long like this... 0xc287291831 or something that looks like that tell me.
