Question GameMax Spark MicroATX Mid Tower Case
Xenokal
37
I am debating on getting this case for a Micro ATX AM5 Build.
I want to know if there is a Side Panel Screen that would mount comfortably into the SSD drive bay
(case in question) https://www.amazon.com/dp/B0B2DP2NC4/ref=twister_B0BGH4YH9R?_encoding=UTF8
Parts I am planning to use.
MOBO: Gigabyte B850M AORUS ELITE WIFI6E ICE Micro ATX AM5 Motherboard
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor
RAM: Corsair Vengeance RGB 64 GB (4 x 16 GB) DDR5-6000 CL36 Memory
GPU: Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card
AIO: CORSAIR Nautilus 240 RS ARGB Liquid CPU Cooler – 240mm AIO
You're going to need the dimensions to that 2.5" drive mounting bracket. The other thing would be that you're going to suffer in the thermals department. The venting on that case is limited to a bottom to top airflow path while the PSU's mounting location would mean that some of the heat in the case would be dumped by the PSU.
Looking through Amazon a rectangular display, together with the cost of the case, might be the same cost of a case that comes with a display, like the Hyte Y70.
Speaking of Hyte, I noticed GameMax have a rip off of the Hyte Y70 with their own Hype series, :rofl:
I was also concerned about the thermals but I went digging around YT for a review and came across this video
View: https://www.youtube.com/watch?v=ruIhyTOwwps
And this video which prompted my interest.
View: https://www.youtube.com/watch?v=JeeOHwnhNLk
in the second video he was kind of janky with his build using double sided tape to hold the LCD screen and PSU.
Which I want to avoid doing. As for your suggestion with the Hyte Y70, I am going for a compact build to save space.
