Hi!
I have HP omen 15-5010nr 4th gen gaming laptop!!
Core i7-4710HQ
*8GB RAM
256 GB SSD
2 GB Nvidia GTX 860M GPU
After playing few minutes of games like GTA V, Ace Combat: Skies Unknown, NFS Payback, FIFA 19 etc, the fps start to drop drastically after almost every 5 seconds.
Laptop becomes hot while gaming (this might be the issue), core temperatures rise upto 90-96 degree.
But the issue is that the temperatures are linked to clockspeed. Whenever I stress the cpu to max clock speed (almost 3.3-3.4 Ghz) the temperature of cpu rises instantly from 60 to 95-96. (Shouldn't it be rising gradually?). Also I changed the processor power state to 90% max and instantly the clock speed decreased and the temperature also decreased instantly.
When I played GTA V with90% state, the max temperature of the cpu remained in the 85-89 degree celcius limit (never exceeded 90). and the cpu clock speed remained within 1.9-2.2 GHz. At these settings, when I played GTA V at 20 fps, the temp and clock speed remained same and the game ran smoothly (no fps drop after 3 hours of continuous play) but when I increased the fps to 40-45, the temp and clock speed remained same (88 degree C and 2.1 GHz respectively) but the game started to drop fps after almost five minutes at 10-15 seconds interval. Same happened at 100% processor power state. At 20 fps the temperatures remained between 90-97 but the game ran smoothly at 20 fps at these high temperatures and dropped fps at 40 fps.
In Metal Gear Solid V, when I put limit to fps (30 fps), the game ran smoothly but when I removed the limit and played at 60 fps, it started to drop fps.
In Ace Combat 7:Skies Unknown I put limit on 60 fps (lowest in settings), the game ran smoothly for almost 5 minutes but then again it started to drop fps.
I dont know if overheating is the issue because GTA V ran smoothly at 20 fps regardless of the core temperatures. Also I ran Intel burn test and stressed the cpu and the results were clean(no issue). The cpu clock does not drop too much when the fps drop occurs (so I think cpu is not an issue). I dont know what is the issue.
Help of any kind is appreciated!
Hi!
Core i7-4710HQ
*8GB RAM
256 GB SSD
Hi!
Core i7-4710HQ
*8GB RAM
256 GB SSD
Core i7-4710HQ
*8GB RAM
256 GB SSD
Hi!
Core i7-4710HQ
*8GB RAM
256 GB SSD
Hi!
Core i7-4710HQ
*8GB RAM
256 GB SSD
