Games freeze randomly and do not unfreeze unless restarted.
z3r0p0int
97
Hey guys,
As of a couple of weeks my games freeze and stay frozen unless I force a restart on them. The ones, on which it happens the most are LoL and CS GO. The thing is, it doesn't keep freezing throughout the day, rather it does once or twice a day and no more. The game randomly freezes, however i can still hear the sound from the game. Once I restart the game it rarely crashes again, and if it does it's in a couple of hours. I tried re-installing windows as i thought it would fix the issue, i tried running different anti-viruses thinking it's some kind of virus or malware but no luck. I read that tweaking the power options could sometimes work, however no luck there as well.
Specs
Intel Core i7-6700
16GB RAM
NVIDIA GeForce GTX 980ti
XFX Pro 650W
Asus H170 Pro Gaming
how are the temps of both your gpu and cpu? probably and issue with overheating , if its unusually high you may need to find a better cooling solution or clean up some parts, or maybe connection issue with your online access perhaps try a ping test
Regarding the the temperature this is what it shows:
CPU - around 30 ℃ (from 29 to 32)
GPU - for now it shows 63 ℃
Median ping: 11.0 ms
With prime95 the cpu load goes to 100% and the temp from 75 to 78
With FurMark GPY load goes to 98% temp increased to about 80degrees/ CPU 17% load 55 degrees
