Games stutter (with NO fps drop!) when I have a video or stream playing on second monitor. Please help me friends!
Andrew Ray
38
This has happened to me ever since I got a second monitor. At first, I only had a GTX 780, and I ran both monitors off of that. I recently acquired a GTX 1080. Main display runs off the 1080, second off the 780. The issue persists. I was told once that it may because the monitors have different refresh rates. I set both refresh rates to be 60Hz. The issue persists. No idea what could be the issue. Please halp me so I can actually make use of my second monitor!
I have a 1440p 144hz monitor AND a 1080p 60hz monitor running off of my one Gtx 1080. I went into my nVidia app and set the monitors up as if I was spanning the screens. Everything worked just fine.
Try hooking both monitors to your main card and see if that works. It very well may be a conflict between your 1080 and 780.
I tried spanning the two monitors off the one GTX 1080. Max refresh rate I can get is 60Hz so I can't really keep that or notice if there is stutter since it looks stuttery to me lol.
Some of you are saying there could be a conflict between the 1080 and 780 though. But like I said, I've tried using just the GTX 1080 and the issue is still there.
The video would be in the background with the game in the foreground and there wouldn't be any effect
Yes and no. Try playing said game in windowed mode and shrink the window. Do the same with said video/stream, too.
Tested. It stutters.
Update: Playing in Fullscreen fixes it. Borderless Windowed is a no-go. Kind of makes using two monitors impossible when in Fullscreen though. Lots of screen tearing in Overwatch, even with a consistent and steady framerate. V-Sync on even produces tearing, so...no matter what I do I am screwed.
