[SOLVED] Gamidas Chione 240R Fans RGB doesn't work
Mar 1, 2019
6
I have Aorus h370 Gamin 3 Wifi ... I installed yesterday Gamidas Chione 240R RGB on my thermaltake view 32 RGB
But the RGB didn't work on fans ... Any possible reason ?
If you've followed through the instruction manual then you should be connecting the LED module to the VDG header on the board, located at the bottom of said board.
