Hello There,
I am planning to assemble a gaming PC. After "chewing" the topic for a couple of times (4K at 30fps? / Full HD at 60fps? / Just run the latest titles for 2-3 years at high settings?), I have come to the conclusion that my sweet spot would be to play games at 1920x1080 resolution on a 120Hz monitor with high or (preferably) ultra settings. So - if I understand well - I would need a rig that is capable of pushing the framerate above 100fps - to utilize the capability of a G-Sync monitor (I know AMD uses FreeSync but I would cling to nVidia).
The relevant components would be the following:
I would do some minor overclocking without a need for watercooling.
So what do you think? Is a GTX1080 an overkill?
Generally speaking about the minimum requirements of gaming with high fps on a high refresh rate monitor, I could not find any instructions on the web about the must-haves:
Another question: take a PC where one game can be run at 100fps on average at ultra settings, whilst another can be run at 150fps on average at ultra settings. Does the G-Sync technology
Thank you all in advance.
Roland
MOBO: MSI Z170A GAMING M3
Memory: Corsair 2x8GB DDR4 2400MHz
CPU: Intel Core i5-7600K
GPU: MSI GTX1080 Gaming X 8G
Does RAM speed play a role?
Amount of RAM? 16 GB or 32 GB?
The more video memory the better?
i5 CPU or i7 CPU?
dynamically change the refresh rate to 100Hz of a 120Hz monitor, and the game runs at 100fps in the first scenario,
forces the game to be run at 120 fps with a 120Hz refresh rate in the second scenario?
Roland
