So I changed by build a bit,(to make it a bit cheaper) anyone who is viewing this probably didn't see my last one, but thats okay. But this build is for mainly gaming, and maybe occasionally editing as well. But my first couple questions are; do I NEED a CPU cooler? If so what would be a decent one in the cheaper range? My budget is around $1000 and can fluctuate within $1-200 if need be. I don't plan on adding another GPU (for awhile at least) so I assume the PSU is fine at 600 watts. I haven't done a huge amount of research, but I still know a decent amount, BUT a concern of mine is if the motherboard is fine. Will it run with everything well? And the case, Im guessing I will have enough space, but with my specs would the airflow be pretty good? Or is it just depend on the case about that.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler: ?
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Western Digital WD Blue 1TB 2.5" 5400RPM Internal Hard Drive
GPU: EVGA GeForce GTX 770 2GB Video Card
Case: Cooler Master Storm Enforcer ATX Mid Tower Case
PSU: Corsair Builder 600W 80 PLUS Bronze Certified ATX12V Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
I don't plan on a SSD for now at least, I know it speeds up loading games, and the computer in general, but I don't feel like that is a necessity right away. I'am open to suggestions, anything that will make this build a solid computer to run games like SC2, Planetside, Possibly BF3-4 on around at least high settings with a good fps. Let me know! Thanks!
CPU Cooler: ?
