Gaming Build Room for Cooler
shoomee
175
http://pcpartpicker.com/p/3dy49 here is my build
What I need to know if everything will fit in my case! I hear the cooler is very big and needs room.
Also will I be able to overclock my PC to around 4.5ghz? Or is a different cooler needed?
Thank you!
Please provide any other details you find important!
Sorry for the delay. I took a shower. LOL But anyway yes, you should be able to do it by yourself. Just follow ALL directions for installing it. You'll need some thermal compound as well. I'll post a link to it off of Amazon. It's cheap enough. Like 5 dollars or so. And if you have any questions when getting ready to install it, don't hesitate to send me a private message to get my attention. I don't mind at all.
If your question is solved, pleae mark it as being solved so that others in the community can benefit from this thread as well. :) Thanks!
Here is link to thermal compound...
Will it block ANY ports on my motherboard? Or should it be fine?
Thank you!
One last question. I am new at this. Do you think I will be able to install this easy enough? I will have help.
Here is link to thermal compound:
http://www.amazon.com/Arctic-Silver-Polysynthetic-Thermal-Compound/dp/B002CZAPUQ/ref=sr_1_3?ie=UTF8&qid=1395372584&sr=8-3&keywords=thermal+compound+computers
