Approximate Purchase Date: This weekend, I'll purchase everything else I need
Budget Range: $900
System Usage from Most to Least Important: I really only care about gaming, maybe some ability to record.
Are you buying a monitor: I have a 720p monitor, maybe suggest a cheap 1080p within my budget give or take a little?
Do you need to buy OS: Yes I do, has to be windows 7
Preferred Website(s) for Parts: Amazon preferably for the graphics card as I have amazon prime, and some credit on there. but any site will do for a good deal is ill save more then $50.
Parts Preferences: I'm hoping to get a good gtx 770 or even a 780 if its in the budget, but I don't think it is. I'd like to OC and be future proof if I want to upgrade in 2-5 years.
Overclocking: Yes I really would like to OC and be future proof, as well as keep the rig at some of the higher levels
SLI or crossfire: No, I only want one graphics card
Your Monitor Resolution: See above, I'd like to buy a 1080p monitor, but I can use this 720p untill i get a good deal on one later on in the future.
Additional Comments: I already own a few of the more expensive items, so that should help with the budget.
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147193
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139028
Note, those are not included in my above $900 budget. So I have about 900 bucks left to play with if possible. Thanks for your help guys!
EDIT: Spelling
Budget Range: $900
EDIT: Spelling
