Gaming build VERY SOON! Review please and CPU HELP!
billybowens
94
Here is my build:
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($59.49 @ Amazon)
Motherboard: MSI B85M GAMING Micro ATX LGA1150 Motherboard ($85.66 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($79.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card ($195.91 @ Newegg)
Case: Deepcool STEAM CASTLE (BLACK) MicroATX Mid Tower Case ($85.00 @ Newegg)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply ($78.98 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Monitor: Acer S241HL bmid 60Hz 24.0" Monitor ($119.99 @ Amazon)
Wireless Network Adapter: Rosewill RNX-N150UBE 802.11b/g/n USB 2.0 Wi-Fi Adapter ($8.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($27.89 @ NCIX US)
Total: $813.85
Generated by PCPartPicker 2014-10-05 00:44 EDT-0400
CPU is between this and a cheap i5-4430. IDK which to get for GAMING. This build is for gaming and gaming alone.
MOBO because it's unlocked and looks nice with the black/red theme I have going on.
Video card r9 280 is what fits in my price range with the best FPS.
CASE because IT IS SEXY and smaller than a mid tower. Little more expensive but this is my first build and I don't want to go 30 dollars cheaper for something less than what I want.
PSU because I believe this one is a good quality one. I think.
I know nothing of wireless adapters so any help will be appreciated there too.
Monitor because it's huge for the cheapest price.
Any suggestions on changes? especially another CPU for gaming?
My budget is under 900 ALL together.
I would personally go for Z97 chipset since it'll support Devil's Canyon CPUs natively.
You're also gonna have to overclock your CPU to at least 4.5 to reduce the bottleneck it's going to bring the R9 280.
Other than than, everything looks great!
Assuming that you live in the United States, you can get this RAM kit too [link]. It's faster at a lower price.
z97 the newest?
Yessir!
I don't believe I will get a devils canyon anytime soon though. i'd like to stick with what i buy here for 2 years or so. probably rebuild another from then too. any suggestions on a certain mobo ?
Try this build:
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Amazon)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard ($124.99 @ Newegg)
Memory: Mushkin Stealth 8GB (2 x 4GB) DDR3-2133 Memory ($74.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Amazon)
Case: Corsair 300R ATX Mid Tower Case ($69.99 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($66.50 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.99 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($29.99 @ Amazon)
Total: $857.81
Generated by PCPartPicker 2014-10-05 01:18 EDT-0400
I've edited the Motherboard and RAM.
I've also edited the PSU
Also got you a different case.
I've also put a CPU cooler. You need to overclock your CPU if you don't want that CPU Bottlenecking the GPU, so that's why I did that.
i prefer Asrock H97 Pro4 ! $15 more
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($187.89 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($74.78 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($78.98 @ OutletPC)
Case: Corsair 200R ATX Mid Tower Case ($39.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($44.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($15.00 @ Newegg)
Monitor: Asus VX228H 60Hz 21.5" Monitor ($129.99 @ Amazon)
Wireless Network Adapter: TP-Link TL-WN722N 802.11b/g/n USB 2.0 Wi-Fi Adapter ($13.65 @ Newegg)
Total: $836.16
Generated by PCPartPicker 2014-10-05 01:31 EDT-0400
CPU: Intel Core i3-4350 3.6GHz Dual-Core Processor ($136.99 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($81.98 @ Newegg)
Memory: Team Xtreem Dark Series 8GB (2 x 4GB) DDR3-1600 Memory ($70.55 @ Newegg)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card ($204.99 @ Newegg)
Power Supply: Rosewill Hive 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Amazon)
Total: $868.34
Generated by PCPartPicker 2014-10-05 03:13 EDT-0400
Here's one with an i3. The G3258 just really won't cut it with a 280. If you were going for a 270/x then yes, otherwise stick with the i3 as a minimum.
Also put in a cheaper PSU, same quality but less wattage. You'd be good with a 450W unit anyway.
Tried to keep as much of your aesthetic parts the same.
