Hello
After upgrade i installed more FAN on my case , but i dont know what the best cooling method for case airflow , this images explain how i installed:
Side fan
Rear fan
Front fan
Side case
Front case
Fan info:
FAN # 1+2+3 controlled , connected to MB , and i set the speed from bios
That releated with CPU , for ex cpu temp 40c these fans 50% , if CPU temp 60c fan 75% .
Fan# 4 + 5 direct to +12v , full speed .
I have 2 problems :
First: high noise of side fan #5 and if i change airflow direction from in to out , noise decrease but temp of gpu increase 🙁
Secound:
I dont know about normal or perfect temp on load for cpu and gpu to know im i in right way or i must change /add or remove fan , airflow direction , speed logic .
Also i still have one more empty place for one more fane "bottom " :
My spec :
I7 7700
Msi 1080 gaming x
Asus b250g
16gb hyperx
2tb hdd
480gb ssd
1200w psu
LG R/W DVD
Asus 144hz 1080p DVI screen
Sorry for long post , but i try to show all details .
Any advice ......
Side fan
Rear fan
Front fan
Side case
Front case
Fan info:
I have 2 problems :
Secound:
My spec :
I7 7700
Msi 1080 gaming x
Asus b250g
16gb hyperx
2tb hdd
480gb ssd
1200w psu
LG R/W DVD
Any advice ......
