Ok so, first of all. thank you for checking out my post! I have a build atm, and I need a gpu, simple as that. I have been looking into the r9 280x, gtx 970, r9 390, etc. I have a budget, sadly, but I'm sure its decent. I'm looking for a card thats under $275 (including rebate). So this is my build: http://pcpartpicker.com/p/49DHMp
I'm looking for 45+ fps, at high (minimum quality I'd want to set at medium) to ultra settings. The games I want to play are Black Ops 3, The Witcher 3, GTA 5, Until Dawn (when it comes out for pc) etc. With those 3 games you can tell, what games I like to play.
If you have a suggestion for my build, edit the ones that are not purchased (except the heat sinks, since I will definitely be buying them) and try to match the price, with a $5-10 pay increase, or an x amount of pay decrease. I want MAXIMUM performance, and a stable build If you can find ways for me to save money money, so I can buy a better gpu, do that too. Any money you save me will go for the gpu
ALSO, please don't say anything about the motherboard, and the cooling issues! I will be adding heat sinks, to the motherboard (since it doesn't have any with it) and have proper cooling in my build to prevent it from overheating etc like some may say.
