Hi all, I always try to do my research, have read of bunch of threads here and elsewhere, but still aren't sure which route to go. I am interested in a high quality, high performance monitor to be used primarily for gaming.
Price range: $350 max, but would also love to save $100 off that
Processor: Intel Core i7-930
GPU: AMD Radeon HD 6990
RAM: 12GB 1333 MHz
Monitor viewing distance: ~18 inches
Monitor size: Size doesn't matter, 24" max
I've looked at:
$308 ASUS VG236HE 23-Inch: http://www.amazon.com/gp/product/B0044UHXJI/ref=as_li_ss_tl?ie=UTF8&tag=gamingsquid-20&linkCode=as2&camp=217153&creative=399701&creativeASIN=B0044UHXJI
Lots of people seem to like it. I understand 120Hz gives a higher frame rate if your GPU can push it, smooth motion?
$300 LG D2342P-PN 23-Inch 3D LED: http://www.amazon.com/LG-D2342P-PN-23-Inch-Widescreen-Passive/dp/B004WK3R4U/ref=pd_cp_pc_2
120Hz and LED. Is LED better/worse/different?
$198 ASUS ML248H 24-Inch LED: http://www.amazon.com/exec/obidos/ASIN/B004EFYG70/besgammon-20
LED, but no 120Hz.
$190 ASUS VE247H Black 23.6": http://www.newegg.com/Product/Product.aspx?Item=N82E16824236112&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Monitors%20-%20LCD%20Flat%20Panel-_-ASUS-_-24236112&AID=10440897&PID=1680882&SID=
Also recommended around here, is it just an earlier model of the 248H?
$188 ASUS ML239H 23-Inch LED (IPS): http://www.amazon.com/exec/obidos/ASIN/B004R5SLJG/besgammon-20
Only $188 for an IPS, holy crap! That's good right?
Is the response time too slow on any of my picks? Would welcome better suggestions. Any recommendations, comments, explanations would be greatly appreciated. Thanks!
RAM: 12GB 1333 MHz
I've looked at:
LED, but no 120Hz.
