Gaming monitor help!
Kakorat119
308
Hey guys,
I am building a gaming pc and now all i need is a monitor. I'm using an i7 4770k and gtx 770 4gb.
I need a monitor that is less than 24 inches and more than 20 inches. (Preferably 21-23)
It MUST be 1080 cuz gtx 770 can't handle much more.
My max budget it $130
It MUST be 75hz or more
A few options to consider(i dont know the hz of these but hopefully 75hz):
http://pcpartpicker.com/part/asus-monitor-ve247h
http://pcpartpicker.com/part/asus-monitor-vs228hp
What do you guys say?
That is more than $100 over my budget... Im pretty sure one of then is 76hz or 75hz....
Yes, but sadly, the benq is way over my budget. So i guess i will go with the asusve247h. Still not sure if the asus is 75hz. Can you plz check? I looked everywhere couldn't find it.
All sites are saying this :
Horizontal Refresh Rate- 30 - 83 KHz
Vertical Refresh Rate- 50 - 76 Hz
