Hi all,
hope im posting this in the right section...
I'm in the process of buying a new monitor for my gaming/coding PC. I am looking to spend around £350 GBP (more or less expensive is ok). This monitor will be taking the place of my 37" tv as I would like a monitor dedicated to PC gaming. I play all sorts of games (FPS,RPG's,action'racing sports etc) so a good all rounder would be best. I am looking at 23/24" or maybe 27 inch in size
With so many choices and after extensive research, I am still finding this very difficult. 120hz 3d monitors were my first choice, with high response rate and little input lag but many reviews and users have kinda slated these due to using tn screens with a poor viewing angle and bad colour.
There are also IPS screens but they seem to be more suited for photographers and designers and less aimed towards gamers.
will a higher resolution (2560x1440) make that much difference?
i have also heard plasma tv's are good for gaming? is this true?
I have not used a pc monitor for gaming since my 2005 flatron monitor which was pretty ok.
Here are a few I have found
yamakasi-catleap-q270
http://www.hardwarecanucks.com/forum/display-units/55097-perfect-pixel-124hz-yamakasi-catleap-q270.html (top link in forum)
my fav so far but a little out of budget...
Viewsonic
http://www.amazon.com/gp/product/B004LXK8LI/ref=as_li_ss_tl?ie=UTF8&tag=gamingsquid-20&linkCode=as2&camp=217145&creative=399373&creativeASIN=B004LXK8LI
Asus
http://www.amazon.com/ASUS-VH236H-23-Inch-Full-HD-Monitor/dp/B002453K5G%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquid1313771-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB002453K5G
Any help would be greatly appreciated, thanks
DIT: ill add my comp specs if that helps
CPU: intel i7 3820
GPU:ASUS GTX 670
mobo: gigabyte UD3 x79 (2011 socket)
HD:500 gb western digital
SD:120 gb OCZ agility 3
Keyboard: microsoft sidewinder x4
Viewsonic
Asus
CPU: intel i7 3820
GPU:ASUS GTX 670
