Gaming mouse - Logitech G700s using batteries
dumisoft
161
Hello everyone,
Today I bought a Logitech G700s gaming mouse. Everything is so cool except charging.
It is very inconvenience to charge with the USB cable while using it. Because the cable is too heavy.
It came with Sanyo 1900 mah battery. And, I have Energizer 2300 mah NiMH batteries with charger. The user manual says use a NiMH battery (1900mah minimum). I have 4 batteries and AC charger. So, I'm thinking about charging batteries using that external charger, and replace a battery when needed.
Is it ok to use those Energizer 2300mah battery at a time?
Thanks for your answers.
The mouse will only draw the amount of power from the battery it needs. Anyone that says otherwise doesn't have a clue what they're talking about.
Some people say higher capacity will damage and reduce the product life time. Is that wrong?
(Thanks for your quick answer)
Thanks ko888 :)
