Gaming pc build help
mkeonpc
55
US
So i am going to be doing some hardcore gaming on this pc on games such as bf3, arma 2, crysis franchise. I just want to know if i can high/max settings these with a 1600x900 res. Looking to get about 40+ fps
http://pcpartpicker.com/p/CJXR
Also idk if it would be fine to just save some money and go with a hd 7850 or reg 7870. Because it isnt going to be in full 1080p
mkeonpc
55
US
I dont want to spend the money atm but when it deem it necesssry ill probally get one. What do you think about the build?
legendkiller
1,812
US
Phenom II X4 965 because it'll be gaming better than the FX you choosed and beside the Phenom II X4 965 can be "OverClocked"... Games for the next few years wont benefit anything more than 4 Cores and for the HAF 912 you'll need side fan for your GPU because it "can" overheat and I'd prefer you get the Antec GX700 for $59 and it's the most value case out there...
mkeonpc
55
US
Ive heard fx cpus are better than the phenom x4 and should i just go with a hd 7850 and a i5 cpu?
legendkiller
1,812
US
based on "gaming" FX isn't a big different at all when compared to Phenom x4($30 cheaper), it's like a i5 2500k to i5 3570k(people would actually get the 2500k if on strict budget)...
mkeonpc
55
US
link to torrent? Prob gunna buy a copy to be safe but i have a friend who needs it.
