Gaming PC Build Help
FlyingManatees
4
Hello, I've been searching up parts and came up with these so far. As for the Power Supply, I don't really know how many watts I'll need :/ I have a 600W one at the moment, hopefully that will handle it. Also do I really need to buy a box copy of Windows 7? I have the OEM version on my HDD and If I do, I might just go to Windows 8 instead. Right now I have a GTX 650 Ti as the graphics card, just gonna run with these specs till I can afford a GTX 760. Feel free to suggest different parts, and my budget is gonna be 500-650$, and I'll be playing heavy games like Battlefield. Thank you!
CPU (AMD FX-8350 8-Core @ 4.0GHz 125W): http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Processors+-+Desktops-_-N82E16819113284&gclid=CIO-x-OAyroCFSjZQgodVw4ACQ
Case (Cooler Master HAF Mid ATX Tower):
http://www.newegg.com/Product/Product.aspx?Item=N82E16811353022
Motherboard (ASUS M5A97 LE R2.0 AM3+ AMD 970 SATA 6Gb/s):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
CPU Fan (Cooler Master Hyper 212 EVO CPU Cooler):
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
RAM (CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600): http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Windows 8.1 Box Copy:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832416712
DVD Burner/Writer: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Total: 602$ (Without Tax, Shipping, etc.)
