Gaming PC build help!
Kinda difficult to fit it under $1000. Consider getting a slightly cheaper case:
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($129.00 @ CPL Online)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard ($115.00 @ PCCaseGear)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory ($89.00 @ PLE Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($62.00 @ Centre Com)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card ($194.00 @ CPL Online)
Case: Corsair 200R ATX Mid Tower Case ($79.00 @ CPL Online)
Power Supply: EVGA...
DougleBi
79
Also forgot to mention that mouse keyboard and OS aren't really necessary unless windows 8 is a lot better the windows 7. I just added them because they were there and I thought I'd see how much it would be for them.
PCPartpicker is just a site for looking for the cheapest price for getting pc components. It may not be always accurate so you should check prices on the actual retailer website.
I would swap the psu for a better quality psu. Corsair VS series aren't good.
PSU:
XFX 550W/650W,
Seasonic 550W/620W
or Antec 620W
Do you need two optical drives or did you accidently included two.
You overspending on the keyboard rather than on the cpu or gpu.
Bump up the cpu to a FX 6300 or FX 8320.
This is also a decent motherboard :
https://pcpartpicker.com/part/gigabyte-motherboard-ga970aud3p
Consider getting a GTX 970 or a R9 280X.
Can you find a website selling the motherboard and psu?
If not we need to find you other alternatives.
What is your budget?
DougleBi
79
Just realised that I couldn't find an Australian site, whoops. My budget is about $1000 but I couldn't go over that.
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($98.00 @ CPL Online)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($20.00 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($115.00 @ CPL Online)
Monitor: AOC E2460SD 60Hz 24.0" Monitor ($159.00 @ CPL Online)
Total: $1060.00
Generated by PCPartPicker 2014-11-23 23:12 EST+1100
DougleBi
79
That's perfect thanks I'm fine with $60 over. Again thanks so much. Hopefully this will do what I need!
DougleBi
79
I'm fine with that 40-50 fps on older games even at ultra. I'll play newer games at lower settings because I'm not too fussed about it.
